12-30-2013 |
4.00 |
Carbi exploring & Dynon EMS Mapping |
The first engine start up produced an idle only (engine stopped as soon as the throttle was opened or the choke reduced) - so today I pulled the main jet and needle seat to check for a blockage - none found. The 2 floats were not quite even so I levelled them and made sure they were operating bowl fuel valve properly. Next step is to restart the engine and see if the fuel delivery problem has been fixed. Also studied the Skyview display - and determined I need to download the engine mapping for the Jabiru 3300. A quick look at the website verifies that it is a project for Robert - the programming is not simple to navigate .... |
