Date:    1-26-2012
Number of Hours:    2.00
Brief Description:    Fitting accessory socket.
Fitted an accessory charging socket - bound to need to charge something during flights ........
As usualy - lots of measuring to ensure the socket doesn't foul anything at the back of the panel - it is lined up between where two rows of circuit breakers will sit behind the panel. Crimped new fittings and a connection box - the first of the proper electrical work! Used the Christmas presebt too - aheat gun - to fit the cable shrink. Much easier than using a hair drier .....
