6-27-2011 |
4.50 |
Rudder cable final fit. |
Removed all the small masking from the wings - over the bearings, bushes and various openings. Hasn't been removed since the painting. Fed the forward cables in place and connected the turnbuckles. Re-tensioned all the bolts and nuts in the pedal assembly, then refitted the assembly. Refitted all the pulleys and re-set all the tensions, fully connected the front cables then tightened up the turnbuckles to test the cable lengths. Good tension with about 1' to go on the turnbuckles so all fits fine. |
