Date:    8-9-2009
Number of Hours:    3.00
Brief Description:    More work on the elevator horn modification.
Did the final trim on the elevators and stabiliers (more fitting and removing of the elevators!) then started coating the balsa plugs. Have now put on two coats of resin.
Built up all the ends with filler - will start to sand to shape when set.
