5-6-2009 |
2.00 |
Finishing work on the spar box instal & engine mou |
Finished the fitting of the spar box - after the successful trial fit of the wings a few weeks ago. Torqued up all the spar box bolts now that the box has been confirmed to be in the right position (ie the wings fitted!). Also trimmed and tidied the spar cut-outs now that I know there is workable clearance for the spars. Fitted the engine mount including the backing plates as required so the rudder pedal assembly support brackets can be mounted to miss the engine mounts. Ably assisted by grandson Cody ..... |
