Date:    12-20-2008
Number of Hours:    2.00
Brief Description:    More canopy frame and fuse finishing
Did more filling on the canopy frame. I am aware from PeterT's plane that you can clearly see the inside of the frame when viewing the aircraft with the canopy open, and in flight with the canopy shut. In fact it is probably the only painted surface (otehr than the panel) you can see when flying. It would be nice to look at a well finished surface while flying!
