Date:    12-6-2008
Number of Hours:    4.00
Brief Description:    Moving toward canopy mounting
Finished fitting gas strut mounts on the panel frame & fitted the frame again.
Bolted the canopy frame to the brackets again to check clearance at the front of the canopy as it opens. Had to drop the fuse to the floor to allow clearance under the garage ceiling, Need to take another 1/8" or so off canopy front edge..
Had a small break and glassed the air-intake adaptors to the inside of the naca ducts - then filed and smoothed the intakes.
