Date:    11-1-2008
Number of Hours:    4.00
Brief Description:    Fitted HS up to marking AOI bolt holes.
Finished fitting the HS brackets - made sure were as instructions and true. Had to remove and pack out as the hole spacing was 1/2 inch narrower than the spacing in the spars. Bolted all together and marked AOI (Angle of Incidence) bolt holes in forward part of HS. Removed HSs yet again!
