11-8-2013 |
1.00 |
Removing & mailing off the Eflap controller. |
After speaking with the factory in the USA, it was decided to remove and email the E-flap controller back to the factory for testing. The multiple leads attached to the controller were routed along a number of wiring harness bundles so I had to pull 4 main harnesses apart to remove the leads. Then weighed the unit so I can fit a replacement weight on the panel for the weight and measure that I want done before the unit returns from the States. Wrote a detailed history and description letter and took the unit to the Post Office and Air-mailed it off ..... |
