12-16-2011 |
5.00 |
Throttle quadrant and cable holder |
Finished adjusting the quadrant to take the connector for the throttle cable. Lots of assembly, stripping and reassembly... Had to work out a way to hold the outer cable on the throttle cable - after two tries with alloy and SS - ened up using a nylon block (laminated cutting board!). Refitted the console and the cable clears all obstructions. Motivated by seeing a finished Lightning land in Perth (in from the East). Great sight to see..... |
