9-17-2011 |
3.00 |
Ram Air Ducts |
Riveted the rubber seal to the front of the ram ait ducts - but then discovered that the rubber can pull mpast the rivets if you pull had enough. So starded again and contact glued as well as riveted - worked well. Fited the ducst to the engine and trimmed the front of the rubber to seal against the engine cowlings. |
