Date:    9-4-2010
Number of Hours:    6.00
Brief Description:    More work front wheel fairing + making up hinges f
Did more work on the front leg fairing - a little more trimming and lots of sanding and filling.
Had to buy some more piano hinge for oil cooler - cut it all to length and made up the 3 hinges. Fitted the hinges to the oil cooler. Not hard, but a little tricky to make sure the rivet heads didn't foul cooler when shut. Made up backing plates for the rivets (don't like pulling pivets against fibreglass).
