Date:    7-10-2010
Number of Hours:    8.00
Brief Description:    General work and lots more sanding!
Trimmed the seat pans to remove the outer ip - the sides of the pan are now flat.
LOTS more sanding - finished sanding the top and bottom cowls. Filled and sanded the cabin vents - 3 times now and getting close to finished. Filled the fuselage top joint (in front of canopy) againand spent hours sanding the fuselage. Probably have about 10 more hours to complete the fuselage sanding - don't know how this is done with the quick-building at the factory???
