7-9-2010 |
3.00 |
Cowl fitting and general sanding. |
Cut the joggle from the back edge of the lower cowl so the cowl would fit more evenly to the firewall. This left a gap so I glassed a piece, then filled, trimmed and sanded it (both sides) to get a good joint. Took many fit, remove, fit cycles. Continued sanding of the fuselage. |
