6-20-2010 |
7.00 |
Canopy and general work |
More finishing work on the canopy - mainly filling and sanding both the inside and outside of the frame and cover. Very slow work as you are working so close to the canopy - and you need to avaoid scratching it!. Started on the NACA duct for the oil cooler - and did more fill on the top fuselage joint. We were also able to do the first test sit to check the canopy clearance - Mark, Andrea, Sheryl & Robert are all fine. I just fit. |
