6-11-2010 |
2.00 |
Changing the prop flange to the 2" extended flange |
Started by cutting out the seat side support rails so they can be repositioned inboard 10mm so better support the seats. Put the first glass in to hold the rails in place (will glass properly tomorrow). Moved on to removing the standard prop flange and fitting the 2" extension flange needed for the Lightning installation. |
