5-28-2010 |
3.00 |
Prep for fitting gear. |
More sanding and filling on the underside - now just need to sand all the gellcoat on the underside to finish. Moved on to preparing to fit the main gear - now the wheels are fully assembled. Sanded the front gear leg tube till the front leg fitted well. Started re-assembling the main gear brake assemblies but noticed that the caliper retaining bolts need to be lockwired - so now need to buy lockwire & lockwire pliers ................... |
