Date:    5-17-2010
Number of Hours:    1.00
Brief Description:    More sanding and filling underneath ....
More filling and sanding on the underside centre joint in the fuse. Also did some fine filling work on the stabiliser to fuse joint. Will probably fill and sand one more time - then flip the plane back upright so work can continue on the cockpit layout and the top centre joint.
