12-24-2016 |
4.00 |
Fuselage - Prepare for final assembly, part 1 |
X-mas eve 2016....Preparing fuselage part for sub assembly started ! From now on, I will follow the instruction as much as possible to speed up the process. Today, I did: - Countersinks dia #30 in the F-843 longerons - Countersinks dia #30 in the F-844 aux longerons - Countersinks dia #40 in the F-844 aux longerons - Relocated the F802D L/G box plate in place, and made countersinks #30 for dimples in skins F820 - Countersinks on inboard side of F817 Seat Back support plates - Relocated the F-804H Center Section Side Plate on the Center Section, and made Countersink dia #40 for dimples in skins F823 LH & RH. In the mean time, André decided to provide some help. He started deburring holes in skin F820. RH first, then did half of LH. I need to investigate if skins F820 are still useable or not. Some of the holes at the bottom have been largely ovalized during the process of drilling the longeron. |
