6-11-2016 |
1.00 |
Fuselage - FWD Fuse structure |
Tonight, I continued working on the fwd fuselage structure for a short period of time. I did: - Figure out which screws are AN509-8R12 in my hardware stock. I shall review my stock against hardware specifications to ensure proper screws are in the proper bins. that is the result of Van's sending the screws mix-up in the same bag - Countersunk screw holes in F822 and F843 - Uncleco and removed the longeron F843-L-1 André came to the shop shortly after I arrived at 8h45. We talked and he had numerous questions about the assembly process for the next steps. Therefore, I estimate I probably worked only 1.0 hours at a slow pace. |
