Date:    4-20-2016
Number of Hours:    1.00
Brief Description:    Fuselage - Seat Rib Skin bad rivet removal
Tonight, I removed qty (18) 3/32 rivets that were not satisfactory following yesterday riveting session with Yves for the seat rib sub-unit.
Following this, I removed a smiling head rivet on F814 RH assy and replaced it with a new one. I also re-installed a rivet at the junction of F814 RH assy and F806 bulkhead. Once that was done, I re-installed the nutplate I had to removed in order to install these rivets, both LH and RH.
I was in the shop from 20h00 until 22h00
