3-31-2016 |
2.00 |
Fuselage - Seat Rib and Center Section |
First started this RV-8 project day by finalizing painting the firewall rotisserie mount. Then I did: - Removed the F804G vertical blocks on F804B-2 assembly due to the too short AN426AD4-14. Holes will be drilled out dia #21 and AN426AD5-16 rivet fitted instead. - Seat rib: removed rivet at jct of F806B and F814 - Re-installed rivets at F806B and F814 junction, both LH and RH. |
