Date:    3-30-2016
Number of Hours:    3.00
Brief Description:    Tooling & Fuselage - Firewall mount paint & Seat R
On this day, I did:
From 16h30 until 18h00
- Painted a coat of blue paint on the Firewall Rotisserie Mount
- Work on the seat rib
From 19h30 until 21h30
- Worked on Seat Rib rivet snags.
- The middle slot on F806B bottom flange was slightly enlarge as it was fouling with the rivet heat to be located in the slot. This rivet is installed to join F826 and F827 seat rib skins together. The slot was enlarge with a dremel cutting wheel, then file and deburr. Later, touch up primer was applied to it with airbrush.
