Date:    1-20-2016
Number of Hours:    2.00
Brief Description:    Fuselage - Aft Fuselage Assembly
On this Wednesday, it was the first time in a while I have been to the shop in the morning. Right after going at the gym, I went to work for about an hour an a half. Then I went home to do some job seeking activities, and came back for another hour prior to leave for the great rock band Muse concert downtown in Montreal.
On that day, I worked on:
- Cut and deburr the replacement part F857B-L-1 Rear Pax Seat Belt Bracket
- Matched, drilled and hole deburr the F857B-1 with F857D-1 and F857E-1, both LH and RH
- Located the F857B-1 and F857C-1 on the longeron F889, final drilled the holes dia #12, both LH and RH
- Disassemble parts common with F889 longerons and deburred
I worked from 10h30 until 12h00, then from 15h00 until 16h00
no pics
