Date:    10-31-2015
Number of Hours:    0.00
Brief Description:    RNC 80001 - Quality disposition - Firewall Sub ass
********************************* RNC 80001 *****************************************
Problem: Hole dia #1/4 drilled as per ref DWG 60 is low edge distance in angle F801H-L-1 and ovalized in F801L-1 and firewall web F801A-1.
Causes for problem:
- External pressure to complete work quickly
- Firewall sub assembly structure was held at an angle, not allowing the drill to be perpendicular to web surface
Engineering disposition to solve problem:
- Re-order and replace parts F801L and F801H-L-1 with new parts
- Drill oversize with Unibit 3/8" dia the ovalized hole in Firewall web to make round again.
RNC 80001 is now closed with activities performed on Dec 26 and 27, 2015
