Date:    11-8-2019
Number of Hours:    8.00
Brief Description:    forming and fabricating bulkhead F6
Drilled holes through the forming blocks and aluminum blanks to mark location of slots. Then took the aluminum out, re-joined the forming blocks, cut off flanges at the bend lines, then separated the forming blocks to sand the radius on the edge of the block. then re-joined the blocks with the alumium blank between them and bent the flanges. then laid out the top, bottom and both sides on assembly table marked with a grid according to the plans. Rivetted the parts together, and there is my bulkhead F6.
