Date:    10-28-2019
Number of Hours:    8.00
Brief Description:    preparation and practice for welding
I made up a lot more practice pieces for welding practice on the motor mount standoffs. the smaller diameter tubing is the actual 1/2" tubing that will be used on the final motor mount. The larger tubing is just some 7/8" 4130 I found at a local metal supplier. using it just for practice in determining angles and making notches for close fit-ups
