I flipped the wing over, levelled it up, and began to drill and rivet the remaining rivets along the spar. I did this wing exactly according to the directions in the manual, which specified to install the bottom skins with rivets into the ribs and aft spar only. The book says to install only five "temporary" rivets along the main spar line, then flip the wing over and install all the rivets on the top skins. this means when I go back to install the remaining rivets along the bottom skin main spar line, I cannot disassemble for deburring of those holes. I may try doing this a different way on the right wing. Drilling the spar line is going very slowly...I only got about a fourth to a third of them done today.
