Date:    3-19-2011
Number of Hours:    8.00
Brief Description:    stiffener channel for pitot static tubes
I got started with installing the bottom wing skins on the left wing. This required first cutting out the hole for mounting the pitot static tube, and fabricating and fitting the stiffener channel for added support in that area of the wing skin. I also got well started on fitting the skins to the wing and drilling the skins to the ribs with # 40 clecoes.
