Date:    8-24-2013
Number of Hours:    8.00
Brief Description:    More wiring
Worked on more wiring. installed the GMC autopilot interface harness and ran the Can bus to the pitch servo. Removed some old servo wiring that wont't work. I had prewired the servo when I thought I would use the Tru-Trak autopilot. Now the autopilot is part of the Garmin system so things changed a little. Ran the RS232 wire for the roll servo and installed the temperature sensor.
