Date:    7-27-2013
Number of Hours:    8.00
Brief Description:    Panel work
Worked on the radio stack. Marked the sub panel and made the cut for the longer trays. Test fit a few times and then added a piece of angle to the bottom side to reinforce. I cut a couple of slots for the audio panel harness. Then spent the hot part of the day inside working on building the harness.
