7-21-2013 |
4.00 |
Air cleaner |
Worked on the air cleaner today. Lines up nicely with the cowl inlet with just a little work. The little offset in the side of the air box is there but is not enough to clear the mixture arm. I will check Monday to see if a offset arm is available. If not it will take a lot of work to make the air box offset larger since I already have this one installed. I reinstalled the cowl since it no longer has any clecoes. |
