6-18-2013 |
3.00 |
Engine arrives |
Engine arrived today. I took it home and pulled it out of the crate. Changed a couple of fittings at the rear and started to mount the engine by myself. 50 minutes later it was mounted and torqued. Connected the fuel line, breather tube, fuel pressure hose and oil pressure hose. Mounted the prop extension, clecoed the spinner on and clecoed the top skin back on. layed the top cowl in place and marked the cut line. Cut the rear edge off to a rough cut and set in place. |
