Date:    9-16-2012
Number of Hours:    6.00
Brief Description:    Electrical
Added a service loop so i can get the panel loose for service. Installed the forest of tabs ground block on the firewall with the negative bolt through the firewall. Started running some grounds. The flap switch is now wired to the flap motor.
