7-22-2012 |
5.00 |
Cabin work |
Took Saturday off from the plane and did an hour in the Cirabria. After that I was a bit under the weather so I layed off. Today I started on the baggage floor skins and riveted them in permanent. Added the platenuts to the seat floors and screwed them into place. Added the spar gussets that go where the gear attachent would go on a A model. Then started on the electric flap system and installed the actuator. Had to drill and cut the center actuator bearing block. |
