Date:    7-4-2012
Number of Hours:    3.00
Brief Description:    Fuselage assembly
Most builders leave the fuselage upside down to rivet the side skins. I felt there was no reason to do this as I can solo rivet most of it with it right side up. I had Marsha help me roll it over and I started riveting. I solo riveted the armrests, F-905 bulkhead then added the baggage bulkheads and riveted those. Riveted the longeron in the areas necessary. Tomorrow will be the aft to forward side skin seam.
