Date:    4-22-2012
Number of Hours:    1.50
Brief Description:    Leading edge light
Cut the bracket to fit the RV-9 and riveted back together as the correct length. Installed the bracket in the wing and started to mount the power pack. Wired the power pack but decided to mount the pack after the new bulbs show up. Duckworks is sending me an updated set of bulbs and a replacement lens for the one I broke doing the other wing. I moved on and installed the remaining tank attach screws into the spar.
