Date:    4-14-2012
Number of Hours:    6.50
Brief Description:    Wing light and flap
Worked on the left wing landing light. Just as I was installing the lens for the last time I cracked it. I used the lens for the other wing to finish this one. I will order a new lens for the right side before I work on it. Sterted to deburr the remaining flap parts and dimple ribs. Cleaned all the parts and primed. Also cleaned and primed the leading edge skins. While I had the left wing on the stand I pressure tested he tank. I did not get a good pressure test the last time and didn't get a good test this time. This tank has a leak that I need to find. Started assembly of the righjt flap. Riveted the forward ribs and hinge brackets to the spar. Clecoed the top skin to the spar and clecoed and pop riveted the forward skin to the front ribs. Tomorrow I will be riveting the skins to the spar and ribs.
