Date:    2-11-2012
Number of Hours:    6.00
Brief Description:    R. fuel tank
More tank work. Finished deburring then dimpled tank skin. Took all parts outside and scrubbed with a scotchbtite pad and soapy water. While waiting for it to dry I deburred the bottom side of the wing ribs and the J stringers. Cleaned everything with MEK. Mixed up a batch of tank sealer and riveted the filler cap, drain fitting and stiffeners. Mixed up a much larger batch and clecoed in all inboard ribs. It will now sit for a day or two and then I will rivet in these ribs.
