1-31-2012 |
4.00 |
J-stringer & skins |
Cut J-stringers to length and drilled in assembly. Time to remove bottom skins so I pulled the bottom skins for the L. wing out of storage. Removed blue plastic from the bottom and rivet only strips on the top. Deburred holes and then dimpled. Tonight I got the L. wing bottom skins done and then removed the R. wing inboard bottom skin and got it deburred. |
