Date:    12-27-2011
Number of Hours:    3.00
Brief Description:    Left wing tank
Started work on capacitance fuel guage sender parts. This required drilling ribs for plates to be added in two places and soldering connectors on the end of some stranded mil. spec. wire. W12759 if I remember correctly. Also drilled end rib for the access hole which will get a reinforcement rig riveted on with plate nuts.
