12-25-2011 |
1.50 |
Left Tank work |
Removed tank from wing and started the rest of the tank work. Still plenty to do on the tank. Final drilled all necessary holes. Machine counter-sunk skin/baffle rivet holes, drilled mounting and strip to #19 for future dimple and #8 screws. Drilled out temporary pull rivets holding attach brackets to baffle. Clecoed nut plates to angles and drilled for rivets. |
