Worked on the two stiffeners at the edge of the trim tab opening. These didn't fit so well and needed trimming to get the trailing edge gap closed properly. Then dimpled trailing edge and edge stiffeners. Scuffed inside of skin at the trailing edge. Mixed up some ProSeal and added a dab on the end of each stiffener and the trailing edge wedge. Clecoed to the table to dry straight and used pull rivets on the edge stiffeners at the trim tab. This will stay for a few days while I work on the trim tab. So I pulled out the trim tab parts and cut the jig pieces. Also cut one of the foam wedges and needed to give up for the day.
