10-9-2011 |
10.00 |
HS riveted |
Needed to stay qyuite this morning until it got a little later so I started working on the rudder. Started cutting stiffeners and removing plastic. Match drill the stiffeners for the right side. When it got a little later I moved back to the HS. Riveted in the forward spar in both halves. Then the rear spar. Only have the back side rear spar to finish squeezing in. |
