10-7-2011 |
2.00 |
VS near finished |
Primed all of the VS parts. Riveted the VS rear spar, doubler and hinges. Riveted ribs to front spar. Received the dimpler shaft for the C-Frame from Avery's today. Deburred the VS skin then dimpled. Tomorrow I will prime and then assemble entire VS. I ordered a replacement aluminum angle and Pro-Seal from Van's on Monday and was hoping to receive today so I could finish the HS as well but will now only be able to finish the right side. I may run out of work so I may start the elevastors. |
