I went to Oshkosh for Airventure 09 and while there I picked up the EFIS wiring harness, magnetometer and OAT probe from Advanced Flight Systems for the second Display I will be installing. Today I began the component installation by running the wiring harness through the sub panel. I further routed the magnetometer cable through the fuselage to the magnetometer mount tray. I mounted the magnetometer, soldered the wires to the connector, installed the connector backshell and all the clamps supporting the wiring harness.
