After consulting with E-magair Tech Support they confirmed there was only one way to enter the ignition timing set up mode. I reread the set up mode instructions and realized that an ignition system P lead when switched "off" closes the switch and grounds the ignition circuit as opposed to a normal electrical circuit where when you switches it "off" you open a switch and remove the ground. So I proceeded with my new understanding and the ignition timing set up worked flawlessly. I also carried out the engine pull through test to make sure each spark plug was firing and firing in the correct sequence. Soon I'll be ready for the first engine start.
