Date:    3-23-2010
Number of Hours:    1.00
Brief Description:    New BNC connector installed in right fuel tank
I received the parts I had ordered from Van's recently including the BNC connector for the right fuel quantity indication system. I soldered the new BNC connector to the harness, secured it to the tank bulkhead and sealed it. Then I also reinstalled the fuel tank access panel and sealed it. Lastly I prepared the tank for a leak check by installing the air charge valve and capping the fuel feed line. Tomorrow once the sealant has had a chance to cure I'll do the tank leak check.
