Date:    3-9-2010
Number of Hours:    4.00
Brief Description:    Autopilot controller connector jumper installed...
During my last work session I found out while doing the autopilot ground check out that the autopilot pitch servo was acting in the opposite direction that it needed to so I started today's work session by installing a jumper between pin 1 and pin 2 of the autopilot controller connector. Now the servo actuates in the correct direction. Next I decided that the wiring running through the rudder lower fairing to the tail navigation and strobe light needed some better protection so I installed some spiral wrap to prevent any possible chafing. Following this I installed some more NO STEP placards. Previously I had installed placards on the flaps. Today I added two more next to each Wing Walk. Lastly I noticed that my right fuel quantity indication had stopped working. Since I had had a little problem originally when I installed the bulkhead BNC connector on the tank inboard bulkhead I decided to replace the connector. So I removed the right fuel tank to get good access to be able to replace the connector. I ordered a new connector and sealant from Van's. As soon as my order arrives I'll install the new connector, seal everything and put the tank back on.
