Date:    9-18-2009
Number of Hours:    4.00
Brief Description:    Cowling engine cooling intake ring sanding...
I decided to work on the smoothness of the engine cooling air intake rings and cowling interface. I sanded all the sufaces smooth and cleaned up the intake rings of mold release wax and epoxy. Once cleaned up I fitted the upper and lower cowling and intake rings and fitted the rubber interface tube between the air intake rings and plenum. To finish off I worked on contouring and drilling the reglassing I had done on the horizontal to vertical stabilizer fairing as well as countersinking the screw holes.
